Unstyled G gaskets
deerman
I need to look at old gaskets but can someone tell me whether you use a AF1075R/RE524064 or a AF1076R/RE524065 gasket set for an unstyled G with the F486R flat head?
AF1075R is for Model G #1000-#7099. AF1076R is for Model G 7100 on up. I don't know if the flat heads stopped at 7099 or not.
Stopped and looked at my G tonight. I definitely need the 1075 gasket set. Got another surprise. Always heard you use Permatex #3 for head gasket. Just found out that #3 is now gone and suppose to use the aviation gasket material.
Have built a lot of two cylinders in the last 20 years,some were pullers with 12.5 to 1 compression [to high] and have never used permatex or had a head gasket blow.I have block and head decked and spray metal of gaskets with alum.paint a couple of times and install when it is still tackey.Run the tractor and get it hot a couple of times and re-tork head while hot.
Thanks for the info. I have also heard some say they use spray on copper gasket sealer. What do you use for the other gaskets like water intake, exhaust manifold, etc?
