4755 warnging lights
I have checked fuse and relays .Relays are not clicking when you turn warning lights on and all so replaced turn signal switch
Most of the time when light issues are not working out the way you think they should it is a failed circuit board, part number RE152042,, they cost about $1,000 from Deere but if you send them to Ag Express in Indiana phone #765-533-4809 they will repair them for about $150
took circuit board out but could not see nothing wrong other than some corrosion on back where relay for left flasher was
The thing is you can't really see what's wrong, some times you can see a burnt wire,, I keep an extra one here to test with, and they are a pain to change, be sure to remove the battery ground wire any little short ruins them..
Of course I'm not saying the board is bad every time,, but if all else don't seem to work out that is where it usually is..Ag exspess turns them around in a few days..
