jd 7410 remote hydraulic problem
The #2 remote outlet stopped working today. All other hydraulic functions on the machine work great including the #1 outlet. Operator said it slowly got slower over a couple hours operation.it works a little, but very slowly with little lifting power. Tractor gets serviced and the implement is hooked up correctly. Any common problems here? I realize it's a little new for the forum but there are more folks here than on todays. Thank you.
i have had a cable on the newer tractor fail the separate enough that the wont move control valve enough to allow full flow. also the part that the implement hoes plugs into can just flat go bad, you can replace them unscrew them from control valve replace and i also have had to replace the control vale due to crack in valve housing . you could switch cable if it has two remote to see if its the cable you can also switch the part the the implement hoes plugs into if that don't solve problem then remove the valve housing by removing cross bolts on the early 7000 series tractor remote there is a small ball between the remote control valves you need to watch for i think on the 10 series that was change but you can go to jdparts.com and look up break down
