Gerald AHM
New User
Folks, you were so helpful before, can you help me again? My "M" isn't charging no matter were I set the ignition switch, plus the engine won't start only when set at high charge. I had the generator repaired and verified it charged, rebuilder questioned the fact that I my need a regulator. There is not one on my tractor, I thought it all was controlled though the ignition switch ?????
Second problem, my throttle lever will not stay up beyond 2/3 throttle, everything appears to be intact re the spring e.t.c. Any suggestions for both or either problems will be appreciated
