535 John Deere baler powering out
My 535 jd baler was working fine until while baling straw, the tractor started to power out. I shut off the pto, kicked out the bale and carried on. Same thing happened when the bale was nearly five feet tall. I see that the large chain on the left side of the baler is very slack and worn so I will replace it. Could that be the reason for the troubles?
108 hp Kubota. It's not the tractor, just wondering if it is the chain on the baler that could cause this issue or something else. I've used this tractor on this baler for three years now
thanks. Couldn't think of that abbreviation this early! Will check everything closer this AM as it was dark last night when I started having troubles
