Fan pulley on a G
dp in nd
I have a G that the fan pulley split in 2. I was wondering if i have to remove the whole assy from the tractor? Or can i just remove the radiator and then remove the keepers on the shaft ? Then proceed from there? Any info will help. Thanks , Doyle
Once you have the radiator out of the way and the keepers removed, the whole she-bang stack of stuff including the front bearing can be slid off forwards.
I will warn you, though, likely you will be ANGRY by the time you get the keepers removed!
