Jd a live hydraulic setup with baker valve
48JD
Hey could some guys post some pics or give some advice on how to run the hydraulic hoses and how to hook them up on a 48 jd a. I have the live pump baker valve and block off plate already
the pressure feeds in the bottom of the baker valve the suction goes in the hyd drain
(quoted from post at 02:35:30 10/01/14) Hey could some guys post some pics or give some advice on how to run the hydraulic hoses and how to hook them up on a 48 jd a. I have the live pump baker valve and block off plate already
Is this the pump that hooks up to the mag/Distb???? I have a John Deere B with one.
Thanks. Thought that's what you were talking about but wasn't
sure if there was a drain on the power trol housing itself
