JD 2555 pulls to right
hillaagsa
I have a JD 2555 that pulls to the right at high speeds while driving down the road. It almost feels like you're hitting the right brake. It only does it when it wants to. Any suggestions?
Parts key 1 is what Tech 7 is referring to. There are 3 per rear axle and axle housing must be R&R to replace them
Repair before that one read wheel locks up while you at full speed on the road.
Also if those brake linings wear through and allow metal to metal contact . The repairs will cost about as much as the tractor is worth.
