lightfoot500
New User
"Re: JD 3020 w JD 146 front loader hyd hookup ?".
thanks,
just getting around to this again.
below here is the link to my original thread that has been retired and can no longer be posted to
http://www.yesterdaystractors.com/jd/messages/516447.html
so first take the return line loose and check if
fluid is bypassing when the levers in neutral ?
if so, look into that deeper.
second, which side is the rock shaft port as shown
in the picture or where would the return be on a
gas 3020 ?
it looks like the supply line is tapped into a
supply in back where the hydraulic lines would
hook in for from a piece of equipment.
here is a utube link if it in action. notice that
the bucket raises then hangs, i had the lever in
the raise position the whole time. so the bucket
should be coming up a bit more smoothly.
https://www.youtube.com/watch?
v=WsWroNPTUhY&list=UU0q73r-05fKE4CkKZ8DxIOA
Untitled URL Link
thanks,
gas 3020 ?
Untitled URL Link
