420 Tach connection
jsborn
If I wanted to add a tach/hour/speed meter to my 420 where would the cable connection be made is a different distributor needed?
Also are there any after market manufactures for tachs for the 420 4 speeds?
Thanks for your help
Jack
(quoted from post at 01:36:03 09/25/14) If I wanted to add a tach/hour/speed meter to my 420 where would the cable connection be made is a different distributor needed?
Jack
My 420W has a plug in the base of the dist. where the tach cable is inserted. I would guess that transmission would have nothing to do with it.
[/quote]
The transmission only has to do with the tach face and ground speed calibration on the face.
The main thing I am interested in is will I need to find a Dist. with a tach input or is there an other way to do it?? My existing Dist. doesnt have a place to screw a tach cable in that I can see.
Looking in the parts book it only shows one Dist. but you say yours attaches to the dist.
I am confused. (what else is new)
js, I went through that with my 420. I am going on memory since I have sold the tractor and the manuals went with it.
Apparently some came without a tack or it was an accessory. Either on or close to the distributor there should be a large plug like you see on trans oil drains. That plug comes out and a tack drive assy screws into that hole. I got a used one from John Shepard and it worked fine. The cable then goes from that drive assy to the tach.
It has been a long time, I can't imagine that not being in the parts book.
good luck.
