[email protected]
New User
I want to take time to thank EVERYONE for their help in diagnosing my starting and carb id problems. I do have it running now. I went through all the ignition tests cleaned all contacts and verified each test all checked correctly. Since the carb was leaking I tapped the carb all over and I guess the float was STUCK.
I removed the air intake hose and there was gas running out, attempted to start and it did, when I put the air intake back on it died, when checking oil level in air cleaner it was well overfull cutting off air intake, refilled to the proper level and all is GOOD.
Thank you all again, now off to correct a no charging problem and the throttle lever that wont stay at full speed.
