4020 Three point lift issues
MH
Neighbors 4020 has been sitting for about a year. Got it started but the lift doesn't work. If you loosen the bolt on top of the valve at the rear it will work but leak, tighten it up and it quits working. Any suggestions??
The plug you're loosening holds a pressure relief valve but I can't think of a reason how that would keep 3 pt from raising. Maybe a real JD tech will answer your question.
What do you mean by "doesn't work"? Will it go up
but not down, down but not up or neither? Also,
is this an early or late model?
