My sediment bowl screws in real easy to the correct fuel line position. Too easy. I'd like to spin it in one more turn, but it gets spooky tight before it gets half way around. I tried multiple Teflon wraps - still seeped. Then I tried a Locktight product made for fuel lines, letting it cure for the full 72 hours as recommended. Better, but still has a "wet" look, and an occasional drip when the engine is shut off. (Fan helps it evaporate?) I'm thinking of adding a brass fitting between the bowl and the tank so I'd have two sets of threads to deal with. Anybody have any tricks for this situation?
