Bob Watkins
This is my 1st restoration and I have had other posts. Thanks for all your help!
I am now at the point I am trying to get the tractor started. It ran before and I did not rebuild the engine.
Carburetor Schebler DLTX 67 - I didn"t have gas flow, a line was plugged. Then I had sediment bowl leaks, replaced, then Carb bowl leaks. I have many new parts and no leaks with a good gas flow.
Wico XH 1042 Magneto - I had weak yellow spark so I have new points(gapped at .015), new condenser, new cap, new gaskets, new plugs (gapped at .030), new plug wires. I now see no spark at all! There was no gasket where the mag fit to the governor. I made one and put it there. Should I have not?
How do I check the mag and see if it"s working correctly?
Thanks for your help!
Bob
Bob
