So, what's the preference for using fine threaded bolts in some cases, like wheel bolts, etc.
My 48 loader cylinder flew apart today when the 4 bolts holding the front cylinder together finally decided to give up. The studs welded to the casing are fine threaded.
I'm wondering if there's an advantage to replacing them with fine threads, or are coarse OK? I assume I need to get some grade 8 1/2" bolts and cut the heads off before the local welder repairs it.
Thanks.
Thanks.
