Tried to fire up my od G (1938) to take to local tractor show. Usually will start on the 3rd or 4th turn of the flywheel if I catch the choke right. Got a good POP out of it, then started getting fuel out of the petcocks. Pulled carb bowl and cleaned it up a bit, put in new Needle and seat I had around for a few years and tried again. Got fuel out of the petcocks soon. Pulled carb again, float was bad. Can't be more than 15 or 16 years ago I changed the float. I had used the old G on a PTO NH baler. Shut it off to go to town, when I came back fuel was running out of petcocks. Lots of fuel to fill 416 cu inches. Was really surprised that time that local dealer had a float n stock. This time I was pretty sure they wouldn't so ordered one with carb kit off this site. Didn't get tractor to the show, maybe next time I should check it out a few days before I guess. I run it about once a year, going to show, always drain carb and leave drain open when returned to shed. Will definitely have it fixed for next years show.
