John DEERE G REAR HUB REMOVE
donarcher
I need to remove rear hubs on model g to replace rear tires hubs are froze to axle and can not get rims over centers as the the wheels are turned so wedge mounts are to the outside and cant get rim over the wedge mount I seen a tool on here once that some one made but cannot find it now any info would be appreciated. Thanks Don
So take the tires from the rims as they are, whats the problem. People do it every day no need to remove the rim from the tractor unless tires are not going to be mounted wear the tractor sits now.
Those rims will fall right over the centers,just take all the clamps off,kick the bottom of the tire in toward the tractor,then lower the axle down and it will fall over it.No need for crow bars or any thing else,you don't force nothing.Ron
Thanks for all then info it helped me a lot never knew that the rim would go over wedges.Iam 83 years old still learn something new .Thanks again Don
