Transmission gear question
Can some explain the difference between these two gears for a JD 430 5 speed double clutch transmission.
# 1 1st Cluster gear pn M4195T ( Fits sn 125000 - 156566)
#2 1st Cluster Gear M3552T (Fits sn below 125000)
I need a replacment for M4195T. Is it possible to adapt the M355T by changing the needle bearings? The gears have the same tooth number configuration.
Thanks for you help
Harry
