1070 splined axle shaft
elkcagg
I was told that the right side axle shafts were subject to breakage & the part is no longer available from John Deere & hard to find anywhere. Is this true? Left side shafts are plentiful & cheap.
You're correct as the RH pinion shaft M804666 is no longer available. Contact your local John Deere dealer for other options. but the LH is still available from JD. Have you thought about trying Yanmar for this part?
