Charles Branch
Today while I was working in the woods I apparently snagged a hydraulic line on a privet root and pulled it loose from the hose. I think it is the short hose that connects to the oil cooler section of the radiator (the red arrow in the image). The white arrow shows where the line enters the transmission housing. I've tried everything I can think of, but just can't get the line back into the hose. I removed the hose clamp, and the hose is loose enough, but I can't get the metal tube to slide into the hose far enough to even try to put the clamp on. From the image it looks like the hose extended at least an inch onto the line, but I can't get it on more than about 1/8 inch, and it slips off as soon as I let it go. Are there any tricks to getting the line on? I thought about trying to bend it forward a little to line up better, but I'm not sure that would be such a good idea.
NOTE: You can't really see the hose itself in the image. Click on the link below for a closeup showing the hose, and showing how the tube looks like it doesn't align very well with the hose.
Closeup of tube and hose end
