Kelly in tx
I have an op. manual and I have an I & T manual, but neither tells how to adjust the shift on my "new to me" 3020. I know there is wear on mine, but I think it still should be able to be adjusted to operate reasonably well.
Gears 1,2,4,&6 seem to go in and stay in gear pretty well, so I haven't messed with the linkage to/for them.
I especially need 3rd gear for current chisel plowing (VERY dry/hard ground).
For gears 3,5,7&8, I've taken the "speed change/range shift rod" loose and have lengthened it by two full turns. Now, mostly, it goes into these gears and stays there. Any ideas to further improve the going into/staying in gear situation? By the way, these adjustment (to the linkage of gears 3,5, etc. don't impact the linkage of 1,2,etc., do they? Thanks for any help you can provide. kelly in tx.
