john in Utah
Clutch Experts,
I am in need of advice on the repair of my 630 Clutch. Specifically, is worth the trouble to pull the pulley gear in order to remove the operating sleeve so that the whipped-out hole in the boss can be brazed close and re-drilled--see photos? I hope it is apparent from the first photo that the hole around the drive pin is enlarged approximately 1/4th of a hole. This lets the sleeve rotate about 7 degrees so that the toggles no longer contact the operating sleeve at a right angle (second photo).
