John deere 1020 leaking crank seal
pdreid300
New User
My 1020 is leaking oil out of the flywheel housing. I assume it's the crank seal gone bad since the tractor is almost 50 yrs old. Has anyone done a crank seal on a gas JD 1020? I was hoping to do it without any specialized tools since I can't seem to find a place that rents the seal removal/installer tool. Any tips would be appreciated. I was hoping that a slide hammer attached to the seal with screws would help removal. And was wondering if I could make some type of instillation tool with a large PVC pipe and some sort of mounting plate that I can screw into. Directions mention a cold chisel to remove, but that seems likely to damage the crank sealing surface if not carefull. Should I do the front seal as well even though it's not leaking? or do you think I have another 20 yrs left in that one. I'm not one to mess with something thats not broken.
There's an engine serial number break for CS seal. I would also recommend checking pto input shaft seal for leakage.
If you have a real early 1020 - the rear main
seal is an odd-ball design and rotates with the
crankshaft . The few I've had to fix got
modified to the newer stationary style that
requires changing the flywheel housing.
If you have the modern conventional stationary
rear-main-seal - you can take off the flywheel
housing and easily press out the seal if you
want. Or just drill small holes in it, thread a
slide-hammer into the holds and yank it out.
Getting the seal back over the crank-boss is
the issue. The lip of the seal will want to
fold over. Without the special tool - you have
to carefully guide the lip with a feeler gauge,
small pick, or something thin.
Mine serial # starts with 087.
I purchased the RE44574 seal and it looks like the rotating type. the inner metal ring spins on a plastic seal that is attached to the outer metal ring.
I don't see an sealing lip that would fold under like you describe.
Wouldn't try installing the seal you got w/o tool. The previous design (not the earliest one) had the wear ring in the seal and was recommended not to remove.
The ring you remove with the chisel cannot be gotten to w/o removing the engine rear housing. You don't cut the ring all the way through. Just strike it in a few locations causes it to stretch enough to slide off.
Is there a reason why I can't just pull the flywheel housing to remove the seal? And would it make it easier to install the new seal as well?
You have to pull the housing to remove the wear sleeve but the new seal has to be installed with the housing installed.
The tool presses them onto the crank and into the housing as a unit.
