Shes coming apart piece by piece. Motor was stuck from sitting outside for years. Crank looks good and rod bearings are barely worn. Still had standard bore, but the number one cylinder is cracked in the middle of the cylinder. Looking for a good set of pressed steel wheels and a good set of front rims also. Suprisingly the transmission looks really clean. The bearing in the first reduction gear cover was shot and the whole shaft wobbles. However the bearing in the maincase for the same shaft is in good shape. Does the first reducion gear get alot of stability from the bearing in the reduction cover?
