Bob Watkins
Restoration of the B.
New Oil in engine and new filter, New transmission/rear end oil; Rebuilt Delco Remy gen., polarized, new wiring done, have spark through new plug wires to new plugs,gapped .030; Removed and cleaned Wico XH 1042 mag then painted cap, did nothing inside Wico. Rebuilt schebler DLTX 67 carb, cleaned gas tank before re-install, Gas valve on, gas in sediment bowl; starter turns over engine. tractor won't start. Seems as though gas is not flowing to carb? Does it need primed? If so how do I prime the carb. Thanks, Bob
