Late A roll o matic question
bigboreG
The large shaft on which the spindles operate on is worn on my A. The bushing was almost gone and galled the shaft. I suspected this as once in awhile the right side would catch and hang up. I have another A for parts that has a good shaft and everything else shows minimal wear also. My question is, does that shaft come out from one side or the other? Or is it fixed in place? Thanks.
Which part is bad? My A had a bad #27 in the attached diagram (what I am calling the axle, where the wheel rotates). I got a "parts" ROM, took it apart, and replaced the whole #27 into my A. I should have used new felt seals, because it leaks a little grease now, but not too bad. Not a hard job, just a little messy.
