4030 tractor
I have a noise that came in the drive line.I think it in the differential.The transmission shifts perfect. It started when I was spraying.When I let out the clutch there was a slight exter delay. Then there was a vibration in the drive line.I stoped and floated it home.I will not be repairing till winter.Just wanting some opinions.Thanks in advance Lloyd
Wheels are not loose and I greased bearings at last oil change.It feels like spider gears.Tim s has mentioned he has worked on this model,i was wondering what he found as a problem.Lloyd
It's really hard to say at this point,, if you think it's the differential take it out and do a tight turn one way for a few circle and then the other way for a few, this will make the spider gears work, if they are failing they will talk to you doing this.
