3020 laoder hookup
Gregman
New User
3020 early (not side console) What are the options for hooking up a loader with hydraulic boom and hydraulic bucket? I want to keep one of the two remotes on the rear of the tractor open. I thought I had seen a 3020 with a loader that was plumbed into the casting on the right side somewhere between the rear axle housing and the side step at some point, but I may be wrong. Has anyone seen this?
Ahead of the brake pedals is a hyd line with an elbow coming out of the tractor. Line feeds the rockshaft. Replace that elbow with a T and feed your aux valve with that.
Return line from valve can go to a ported cover at the transmission oil filter. Can make your own ported cover by welding a pipe fitting to the cover, and drill a hole through the cover to allow oil flow. Both scv units are still available for use.
(quoted from post at 21:58:32 08/30/14) Much has been posted on this, you will need a CCLS valve and some fittings.
CCLS valve is for a Ford & some other later model tractors but not JD 3020. CCLS valve has a small sensing line not utilized on closed center hyd's. JD 3020 requires a closed center valve or open center converted to closed center
Jim,
Thanks for correcting me, I knew what to say, but am working on converting my 6610 off the remotes and onto a separate CCLS valve.
That is on my brain.
(quoted from post at 10:04:16 08/31/14) Jim,
I have a decent understanding of CC hyd's but the 5610 I once owned with CCLS hyd's kicked my back side.
I hope to understand it by the time I get done.
I learned a lot on the fuel injection project. I did everything at least twice on that, ended up pretty good on third pass.
