Wico C mag bushing
35gpa
Whats the best way to install new brass bushings? It seems more times than not when I get them installed, they are too tight and have to be reamed out for the rotor to turn freely,yet not have any play. I use a small press to install them and try not to put any more pressure than is needed. Thanks for any help
I've always had to have the bushing reamed also. I sell my Wico C mags and put the much better Wico X mag on my tractors.
That is part of the job to get a perfect fit even if the shaft may be worn a bit. Do you load them with oil before pressing?
