3020 3 point hitch issue
Anonymous-0
I have an early model 3020 and the 3 point just recently started acting up. On the D/LD/L selector lever, you can start tractor with lift in the L position, move it to the D position without touching the 3 point control lever and the lift will raise almost all the way up on its own. Switch lever to LD position and it goes down but not all the way, and put it on L position and it goes all the way down. Works fine it L postion. LD position just doesn't allow it to go all the way down. What causes this. Thanks
You only need LD or L when operating a 3 pt hitch plow. All other implements should be operated in D. To correct the problem you mentioned you need to get a JD 3000 series service manual and adjust the L/D mechanism following the SM step by step.
