Bob Harvey
Dear Sir. Thank you for your reply to my question regarding 'O' rings for the pipes to the powertrol on my '60'. After days of searching, I found my PC 244 parts catalogue (really only took about 10 mins.) and blew the dust off it. I discovered that the suction and pressure pipes have different 'O' rings. I had already come to this conclusion 30 yrs. ago. One is more bigger than the other. JD Corp. in their infinite wisdom have decided to give DIFFERENT key codes for EACH end of a common pipe (silly). To chastise you for your help would be churlish, BUT, you stated that it took 4 of the same sized(part numbered) 'O' rings. You sir were in error and I hope this won't happen again. My lawyers, Dewey, Skrewem and Howe have been apprised of this situation. ;^)
