4010 hydraulics
I have a 1961 4010 that the steering and brakes have been coming and going now I have no steering at all. Is there a way to drain or clear the priority valve?
When that happened to my dad"s 4010, we found the screen on the suction tube completely plugged. It is located at the lower left side of the tractor, between the rear axle and battery box area. Drain the tranny/rearend first. Have not had a problem since cleaning it.
Do any of the other hyd's operate? How long since hyd filter was changed and trans sump screen checked/cleaned? Have you ever checked stand-by pressure? Stand by should be 2250 psi
