Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: 60 block removal
Mike n Mo
08-23-2014 14:48:26
The block will come out with the fan shaft in place. IIRC, you'll need to remove the top row of head studs to be able to remove the head with the manifolds still on. I do agree with B&D, time and funds permitting, to pull the governer off for a complete inspection, and put in a reground cam and lifters. Also check clearance on the crank main bearings. I replaced the main bearings a couple of years ago on mine, and they were shot. Poor oil pressure at idle, and pushing oil thru the clutch side seals. The fanshaft drive gear set was worn enough to jump a tooth every now and again. Good luck. Mike
