Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
60 block removal
08-23-2014 14:23:46
Thinking about overhauling my 60, will the block come out with the fan shaft intact or will it need to be removed also?
08-24-2014 06:28:24
 Re: 60 block removal in reply to kemper, 08-23-2014 14:23:46
Be VERY careful torqueing that head back on. Those 60 blocks can crack very easy. There is a step sequence to follow and do it exactly. Over torqueing will crack the block inside the cylinder at the stud location and you cannot sleeve it.
08-24-2014 12:29:36
 Re: 60 block removal in reply to Prairieplow08, 08-24-2014 06:28:24
My block was cracked when i got it.Took the block out and to the machine shop.They bored an sleeved it back to std.It has been trouble free for 12 yrs.Can't really remember having to remove the fan shaft.
Carlyle Hoffman
08-23-2014 16:17:08
They , the parts will STORE, nothing says they need to be used in your 1st life time. If it ain't broke don't try to improve it.
Mike n Mo
08-23-2014 14:48:26
The block will come out with the fan shaft in place. IIRC, you'll need to remove the top row of head studs to be able to remove the head with the manifolds still on. I do agree with B&D, time and funds permitting, to pull the governer off for a complete inspection, and put in a reground cam and lifters. Also check clearance on the crank main bearings. I replaced the main bearings a couple of years ago on mine, and they were shot. Poor oil pressure at idle, and pushing oil thru the clutch side seals. The fanshaft drive gear set was worn enough to jump a tooth every now and again. Good luck. Mike
08-23-2014 14:28:44
Why not have a look at the governor gears, bearing and weights etc at this opportunistic time ? Why an overhaul ?
Have you considered the cam and followers during this overhaul ?
08-23-2014 14:53:50
 Re: 60 block removal in reply to buickanddeere, 08-23-2014 14:28:44
Actually nothing wrong with the tractor, it runs like a top but I have a 60 for parts that has been rebored and oversized pistons, head and block planned, with hardly any hours on it,just thought I would take advantage of the parts before I get rid of it
coonie minnie
08-24-2014 07:29:09
 Re: 60 block removal in reply to kemper, 08-23-2014 14:53:50
I too might be interested in the parts...
08-23-2014 19:38:07
Kemper, if you don't redo your 60 I maybe interested on your parts 60 pistons,rings,rods for my A.
08-24-2014 13:52:21
 Re: 60 block removal in reply to husker44a, 08-23-2014 19:38:07
I'll let you know if I end up with parts for sale, I probably won't work on it until this fall
