TractorLinks.com
Show Parts for Model:
broken wheel on 60
grampajohn
08-22-2014 20:56:53
i bought a 60 and i saw it has a crack in the wheel casting in front of where the pinion gear is.
has any one tried to weld them up and will it hold or is it going to have to be replaced?
thanks gramps
grampajohn
08-23-2014 19:23:17
 Re: broken wheel on 60 in reply to grampajohn, 08-22-2014 20:56:53
yes its a fresh crack. its not a huge crack. here is a pic. its not the window style. id prefer to fix if it would hold.
Kent Petersen
08-26-2014 17:48:11
 Re: broken wheel on 60 in reply to grampajohn, 08-23-2014 19:23:17
Hi grampajohn run it that way till you can get one i have on hand if you get out this way
Carlyle Hoffman
08-23-2014 04:45:04
There are 1000,s parted out or in yards , why fix it. Is it the WINDOW wheel or the DONUT style?Window style throw it away.
grampajohn
08-22-2014 21:29:53
or would you not worry about it and drive it?
kemper
08-25-2014 08:40:33
 Re: broken wheel on 60 in reply to grampajohn, 08-22-2014 21:29:53
my 60 has a crack in the same place,someone welded it and it cracked beside the weld,its never gotten any bigger and the wheel stays tight so i have not messed with it yet...
D-
08-23-2014 06:18:21
Drive it.
coonie minnie
08-23-2014 04:59:20
If the wheel shows no sign of changing or loosening, I might just leave it alone. You might be surprised what it takes to get the wheel loose!
How big is the crack, and does it look fresh?
Mikein Ky
08-24-2014 14:45:04
 Re: broken wheel on 60 in reply to coonie minnie, 08-23-2014 04:59:20
My 60 did the same thing and it wasn't long until it got bigger. Best buy a used center and replace it. They aren't real expensive.
