Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Tim S Model 60
Bob Harvey
08-22-2014 16:48:29
Howdy again. It is well known that you are the Worldwide Expert on the Model 60 JD, so, are the 'O' rings to the powertrol pump just regular 'O' rings or some silly JD thing ? Sizes would be helpful. Silly old phart of a tractor has decided to leak there after I've owned him for 43 years ! TNX, Bob
Tim S
08-22-2014 16:51:27
 Re: Tim S Model 60 in reply to Bob Harvey, 08-22-2014 16:48:29
They are regular o-rings,,I can't remember what # they are but I used my standard o-ring kit to replace mine..you can look the number up and put it in the Deere parts cart, then click on the part number it will go to a screen that will tell you the size...
Bob Harvey
08-22-2014 17:10:20
 Re: Tim S Model 60 in reply to Tim S, 08-22-2014 16:51:27
Thanks Tim. I sorta wanted to know what size to save me the embarrassment of not having them in my selection and save the fuel from a 15Km drive to the joint that has 'almost' everything ! Tnx again. b
Tim S
08-23-2014 07:09:22
 Re: Tim S Model 60 in reply to Bob Harvey, 08-22-2014 17:10:20
It takes 4-A3190R standard size 115
n
Weight: 0.00 LBS 0.00 Kg
Inside Diameter 0.674 IN
Nominal Section 0.103 IN
Standard Number Code A
Standard Number Size 115
Durometer 90
Material H4B
Finish Note
Bob Harvey
08-23-2014 17:20:53
 Re: Tim S Model 60 in reply to Tim S, 08-23-2014 07:09:22
Thank you .
Copyright © 1997-2015 Yesterday's Tractor Co.
