60LP idles but won't high idle
Sean Pavelka
New User
WE thought about it being fuel but weren't too sure seeing we are not edumacated on propane other than the basics. What's the purpose of a liquid line valve and a vapor line valve on the bottom of the tank leading to the strainer?
Make sure it is started on vapor and run tractor till it warms up....If you start it on liquid it will freeze the regulator.... If you have been running it on vapor try adjusting the load needle that is located on top of the carb between the two barrels. Had a 730LP do that when I got it several years ago, open the load needle a couple of round and it fixed the problem.... Check the vent hole on the regulator to make sure a wasp has not plugged it up, hope this info helps you out.
