Anonymous-0
I recently removed the drums from an early B and found two long shoe linings on the left side and two short linings on the right side. The right side casting was broken so another one was found in a Minnesota salvage yard. This one also had two short linings. Is this correct?
Second question: Late B and 50 linings with eight rivet holes are readily available. Is there any reason to trim them to the short length since full length linings were used on later tractors?
Thanks for any help.
