fixerupper
I have a Westendorf box scraper that I pull with a 4650 Deere and an IH 1086, depending on which tractor is available. It has two 3X8 cylinders, one for the raise and one for the tilt. This introduces a small amount of the wrong oil into both tractors. Can a small amount be mixed without adverse affects? It's switched between tractors maybe four times a year with the primary tractor being the 4650. I do change hyd oil yearly in both tractors and I use CIH brand HY Tran in the red one and Deere branded Hy Gard in the green one. This is the only implement shared by both tractors. Thanks, Jim
