power steering flow control valve
Leaking bad from little sealing washers on power steering control valve. Hope I can still get them. I have an IT manual but still can t figure out where to add oil. My steering is about gone on the 630 . Hope if I get those little washers and add fluid it will come to life. Do I need John Deere fluid for sure ? Thanks anyone.
Add &/or check oil at dipstick(parts key 37 A or 37 B)
Are you looking for the sealing washers on the flow control adjustment nuts?
Part # is A5364R, they should be readily available for under a buck.
