Aussie Ken
helping a friend with a unstyled low radiator G he bought from USA and had shipped to Australia
It came with a Wico X long lug mag installed - but there were 3 gaskets, 2 of which were twice as thick between the mag and governor, and the attaching bolts were not completely tight. when rolling the tractor over the impulse was not working on the mag. I took a brand new Wico X mag that he had and checked the lug on it as well - same lug and when I put it in place the mating surfaces would not fit either. It appears that the step on the lug bottoms out on the mag drive coupler - it looks like the coupler is on the governor shaft the correct depth - we did try a short lug mag as well, but it would not engage at all - has anyone had this problem? I think the governor had been rebuilt and the coupler should have been installed farther on to the shaft - what is the best solution? - we could grind some of the cast off of the shoulder on the long lug, otherwise the governor shaft removed and checked over--
any suggestions appreciated
Ken
Ken
