6230 John Deere Rear Lift
Anonymous-0
I need some help if any of you have had this problem. The rear lift quit working, will not go up and down. It has a cab, I think all the fuses have been checked, I really don't know the symbol for the correct fuse. Hydraulic oil is new and full. Everything works front loader, power steering, but not the rear lift. I need to move some hay and could use some ideas. Thanks for your time.
I am thinking that on that new of a tractor it would bring up a fault code on the instrument cluster. Does it have both a rocker and a slide switch to operate the hitch? Do neither of these work? Not sure on this series if there is a "lockout" to prevent the hitch from moving. Sorry thats all I have got.
if the 3pt is up put in down position i have had to take a loader to one to get it down tell you get some weight on it also check under the flip up cover on lift control the is a couple button that control height and speed
