JD 2520 hyd remote leaking
Good Afternoon from rainy NE Pa. We need the rain. I was out cutting grass with my JD2520 and 350 cycle mower, looked back and saw the mower cover in something wet. Checked things out and discovered that the hydraulic remote was leaking pretty bad, coming out the bottom of the remote. I believe that I will rebuild it. Does Deere make a rebuild kit for these remotes, or do I need to order everything item by item. If they don't make a kit, what sugestions on what to order to rebuild these remotes. Any help in this matter would be greatly appreciated. I also heard about a tool that Deere sells to take out the seals in the remote.
Thanks. Al Shaulis
1 Re10924 upper kit $53
1 AR82570 lower kit $25
4 AR86535 poppet valves @ $52 $208
Labor to re-seal and bench test $250
total (if shipped to me) $536
(this will have improved seals)
Tim, I just purchased this tractor, it has the remotes couplers outlets that you can use pioneer hookups. Will this be a problem when you rebuild them. I like the idea of using pioneer hookups. Al.
