Anonymous-0
When I resealed my rocksshaft I noticed scvs leaking dumping oil into the sump. Took it to local hydraulic shop to save time. Put it on today. Outside valve wasnt returning to detent. Leaked and didnt work right. Took valve apart and found spring between parts 4 and 22, and only 1 set o and backing rings on pressure valves. Shouldve done it myself. My question is about the bushings for the spools. Two are different and have a smaller diameter shoulder. Do they go with pressure or return ? Shoulder pointing to valve bore or bottom plate. Thanks in advance, Bob
