TractorLinks.com
Show Parts for Model:
John deere paint
Waucondajim
08-13-2014 19:21:26
Hey guys , what kind and type of paint should i use on my 1952 jd 60 ? Want it to look good but do not want to break the bank . Use to spray acrylic , but now the game is changed .
newgenjdcollector
08-14-2014 17:42:35
 Re: John deere paint in reply to Waucondajim, 08-13-2014 19:21:26
If you want your paint job to last and last, then don't use paint off the shelf at JD. Yes it looks good for awhile but be warned because it will fade over time as it has little to no uv protection. I think it's fine for implements or quick and dirty save some money paint jobs, but not so much for tractors. Especially when you've put a lot of time in your prep. I have found the JD paint to be runny when sprayed and take a long time to dry. Hardener does help but nothing like professional paints that can be dry to the touch in 30 min or so. Once you have sprayed a good urethane, you will never look back. On a side note, learning to clearcoat is a great skill to have and will enhance any paint job if you decide to do so. I clearcoat just about everything I paint these days.
JDChris
08-14-2014 17:06:30
First off JD paint is not that great! I have been painting with Montana Big Sky paint Sprays and sands nice great shine not priced to high holds up againt gas leaks and antifreeze better I get it at Agless Iron in Ohio Steve 740-502-5454 ITS WELL WORTH IT ! Here are 2 that are done in it
Mike M
08-14-2014 12:25:51
Why is everyone so obsessed with hardener ?
That stuff is extra hard on YOU !
nlastovi
08-14-2014 14:47:23
 Re: John deere paint in reply to Mike M, 08-14-2014 12:25:51
I would suspect that it is related to people reading the material from the folks that design and manufacture the paint. Many paints specify (for example Omni MAE Acrylic Enamel from PPG) use of it and some might suppose that the people who make it know what they're talking about. There are a slew of different types of paint (alkyd enamel, synthetic enamel, single stage urethanes, acrylic lacquer, etc. etc. etc.) and some need hardener to improve the final product (durability, speed of drying, etc).
Dave H
08-14-2014 06:09:40
I did my 420 with the JD labeled paint. It was OK, nothing magic about it and I did use hardener. I found the surface quite brittle.
I switched to a single stage enamel. Use both Dupont omni and PPG nason. The difference is night and day but you will have to anty up. I have decided that when it gets down to what people look at, it is not the time to go the economical route.
66 Caprice
08-14-2014 06:02:04
Just finished a 1953 "60" Used John Deere Classic Green with J.D. thinner and hardner from Tractor Supply Mixed 8 parts paint 1 part thinner and 1 part hardner. Came out nice and smooth and glossey.
David G
08-13-2014 20:22:00
JD paint is acrylic enamel, works fine, but I would add hardener.
Mark-IA
08-13-2014 22:59:35
 Re: John deere paint in reply to David G, 08-13-2014 20:22:00
John Deere paint is Synthetic Enamel. Use the appropriate hardener.
