TractorLinks.com
Show Parts for Model:
1020 throttle
rlh22
08-13-2014 18:11:29
throttle no longer stays in place where do I start adjusting it is a gas keep sake my dad bought new Thanks
Bob
08-13-2014 21:03:24
 Re: 1020 throttle in reply to rlh22, 08-13-2014 18:11:29
Looks like there's spring-loaded friction discs on the rod from the steering lever that varied with serial number.
They could be worn or the spring-loaded mechanism that keeps tension on them could have rusted solid and need freeing up.
You'll have to take a look and see what you've got.
Cliff Nelson
08-14-2014 05:08:53
 Re: 1020 throttle in reply to Bob, 08-13-2014 21:03:24
Check for broken or missing roll pins also. I've seen that before.
Richard in Bee
08-14-2014 09:20:27
 Re: 1020 throttle in reply to Cliff Nelson, 08-14-2014 05:08:53
All I can say is good luck. I've got one of the first two versions, can't remember which because it has been a couple of years since I had it apart. I replaced the disks, which is quite a bit of work and it still creeps up.
Apparently Deere knew it was a problem since they had three different designs during the eight or nine years of production.
D-
08-15-2014 07:27:45
 Re: 1020 throttle in reply to Richard in Bee, 08-14-2014 09:20:27
Richard in Bee
The first version shut off with the throttle. The lever hinged up a little allowing it to be moved a little more like the Waterloo tractors.
I guess the next version was for electric shut off.
Richard in Bee
08-15-2014 07:51:56
 Re: 1020 throttle in reply to D-, 08-15-2014 07:27:45
Mine is a gas burner so I shut it off with a key. :D
But I know what you are saying.
