TractorLinks.com
Show Parts for Model:
JD 148 Loader set up
Bardoin
08-13-2014 07:52:44
I recently purchased a 4030 with a 148 loader. The loader is using the tractors hydraulic remotes for operation. I'd like to install a power beyond block and a joystick. Just looking for advice on what type joystick to use and how to install power block. Thanks,
larryanderson
08-14-2014 04:54:48
 Re: JD 148 Loader set up in reply to Bardoin, 08-13-2014 07:52:44
Another option on 148/158 is the factory levers that were an option which are mounted on a steel rail from the right loader mast toward operator these had two or three levers depending if grapple equipted.Requires no drilling in fenders or platform and can be plumbed to SCV or better into line by brake and returned to filter.It has all valving included.I happen to have an extra 515-290-4336
Bardoin
08-13-2014 20:11:32
It's an open cab set up. I'm not new to tractors, but am new to installing additional equipment. Thanks for all y'all's help an advice.
Davisfarms
08-13-2014 19:22:00
Ihave a power beyond block that is shown in this post.I LIVE IN TN.well under mother deere price
rockyridgefarm
08-13-2014 13:15:48
Hey Jim,
Bardoin never said whether or not the 4030 has a cab. Would you want to put the hydraulic unit in the cab with you like that one is? Seems most joystick controls run cables down out of the cab and have the actual valves safely outta the cab...
Tx Jim
08-13-2014 13:53:07
 Re: JD 148 Loader set up in reply to rockyridgefarm, 08-13-2014 13:15:48
Thanks & that's a very good point. Surplus Center,Baums & Bailey's sells cable operated valves that can be converted to closed center for a cab tractor
Bardoin
08-13-2014 10:28:05
Thanks for the info Tim.
Tx Jim
08-13-2014 10:45:44
 Re: JD 148 Loader set up in reply to Bardoin, 08-13-2014 10:28:05
You're welcome,Jim from Texas
Tx Jim
08-13-2014 09:53:30
Here's JD PBY block. I personally prefer to tee into the pressure & rockshaft oil return lines.
AR71331 Selective Control Valve - KIT, SEL CNTL VAL AUX HYD OUTLET ADD 261.21 USD
A joystick closed center valve can be obtained from Surplus Center.
This post was edited by Tx Jim at 09:58:10 08/13/14 2 times.
