I have installed a 45W loader on my 1949 BW tractor. The weight has made the steering too hard. I have a live hydraulic pump with a 10 gallon reserve tank and would like to add power steering. I hear that Behlen and Char-Lynn made power steering kits. I also hear that a "priority flow valve" is needed to operate both the loader and steering off the same pump. I have ordered a "priority flow valve" that is listed for use on a model B & BW tractor. So I need help to identify what power steering unit I would need and how to locate one. I think the power steering hydraulic motor requires that I cut the steering shaft just in front of the support. The cast support with the throttle and radiator shutter control looks like a good way to anchor the motor.
Roy
Roy
