Re: 4010 pump problems
So i received my pump from the rebuilder.
Timing marks were lined up on the fly wheel and
I checked the mark that is on the slot where
the pump sits to ensure that it was in tbe
correct spot. I also checked lines on the pump. I bled my lines and the tractor
started right up and sounded great. It ran for
2-3 minutes then it made a knock noise by the
pump which I was standing right next to and I
saw the pump turn and the tractor immediately
died. Everything was tight mount bolts were
very tight I double check everything. Where am
I going wrong??? Thanks
The head and rotor seized in the injection pump.
Could have been because of dirt, debris, or water in the fuel.
Sadly, $$$$$, unless, for some reason, the pump folks will warrantee it.
