Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 4020 quick hitch?
Tx Jim
08-12-2014 05:50:02
Larry
The lower attaching hole in a Cat lll QH is 1.434" in diameter and a Cat ll hitch requires 1.110 attaching pin. JD has no bushings that will correctly fit Cat lll QH for Cat ll pins that I'm aware of. How would you keep the inside Cat lll to Cat ll bush (if available) in a Cat lll hitch short of welding it in place? I guess one could cut bushings to correct length then hold them in place with a longer pin & shim washers
larryanderson
08-12-2014 07:51:53
 Re: 4020 quick hitch? in reply to Tx Jim, 08-12-2014 05:50:02
Jim they just fit in CATIII part and separate pin diameter is CATII.It works in reverse to install CATII coupler on CATIII then there is a bushing that goes in ball. I think I have some bushings but like always I might be wrong.
Tx Jim
08-12-2014 08:43:36
 Re: 4020 quick hitch? in reply to larryanderson, 08-12-2014 07:51:53
Installing Cat ll QH on a Cat lll 3 pt is easy concerning bushings but installing Cat lll QH ON Cat ll 3 pt is different.
